ja das Update ist drauf, das Problem war aber schon vorher. Das AGR Ventil ist neu. Und habe es gestern mal neu über VCDS justiert. Hat nichts gebracht. Was noch ist das meine zweite Glühkerze an Zylinder zwei defekt ist. Die mache ich heute neu rein. LMM hab ich auch gewechselt brachte aber auch nicht den Erfolg.
Villeicht hat die Glühkerze doch was zu sagen. Nicht nur am Start sondern auch die ersten paar Km beim fahren.
Wegen Messwerte PDF.
Das Auto hat nun 101000 km runter.
11:50:21
181 Einspritzmengenabweichung Zylinder 1 -0.66 mg/stroke
182 Einspritzmengenabweichung Zylinder 2 0.80 mg/stroke
183 Einspritzmengenabweichung Zylinder 3 0.17 mg/stroke
184 Einspritzmengenabweichung Zylinder 4 -0.30 mg/stroke
das sind die Messwerte im Stand.
,1.96,-0.76,0.12,1.44,0.48,-0.05,0.85,-0.66,
,4.14,-0.75,2.32,1.45,2.68,-0.04,3.04,-0.65,
,6.11,-0.77,4.51,1.44,4.88,-0.06,5.25,-0.60,
,8.29,-0.79,6.47,1.43,6.83,-0.12,7.19,-0.54,
,10.51,-0.81,8.66,1.44,9.04,-0.09,9.41,-0.55,
,12.72,-0.80,10.87,1.43,11.23,-0.08,11.59,-0.54,
,14.66,-0.81,13.08,1.42,13.44,-0.08,13.80,-0.53,
,16.86,-0.77,15.02,1.41,15.38,-0.09,15.75,-0.54,
,19.06,0.00,17.22,1.33,17.59,-0.09,17.95,-0.46,
,21.25,0.00,19.43,0.00,19.79,0.00,20.15,0.00,
,23.43,0.00,21.61,0.00,21.97,0.00,22.33,0.00,
,25.62,0.31,23.79,-0.01,24.15,-0.07,24.51,-0.15,
,27.81,0.19,25.98,0.01,26.36,0.10,26.72,-0.41,
,30.00,-0.05,28.17,0.23,28.53,0.06,28.89,-0.44,
,32.18,-0.15,30.36,0.49,30.72,0.13,31.08,-0.40,
,34.40,-0.45,32.55,0.55,32.92,0.02,33.29,-0.41,
,36.58,-0.71,34.76,0.84,35.12,-0.02,35.48,-0.31,
,38.77,-0.80,36.94,1.00,37.31,0.00,37.67,-0.26,
,40.97,-0.89,39.13,1.11,39.49,-0.07,39.86,-0.20,
1,43.15,-0.88,41.33,1.20,41.69,-0.14,42.05,-0.19,
,45.34,-0.87,43.51,1.26,43.87,-0.16,44.23,-0.22,
,47.57,-0.87,45.70,1.27,46.07,-0.21,46.44,-0.19,
,49.77,-0.84,47.94,1.34,48.31,-0.31,48.67,-0.17,
2,51.98,-0.86,50.14,1.35,50.51,-0.33,50.87,-0.19,
3,54.17,-0.87,52.34,1.37,52.70,-0.31,53.06,-0.20,
4,56.37,-0.82,54.53,1.46,54.90,-0.41,55.27,-0.20,
,58.57,-0.77,56.73,1.49,57.10,-0.51,57.46,-0.22,
,60.78,-0.73,61.14,1.66,61.50,-0.59,61.87,-0.35,
,112.44,-0.06,112.80,0.83,113.16,-0.18,113.53,-0.54,
,114.63,-0.24,114.99,1.11,115.35,-0.42,115.71,-0.31,
,116.82,-0.52,117.18,1.27,117.54,-0.47,117.90,-0.28,
,119.02,-0.31,119.38,0.87,119.75,-0.03,120.11,-0.64,
,121.22,-0.12,121.59,0.70,121.95,0.07,122.31,-0.64,
,123.42,-0.12,123.78,0.70,124.15,0.07,124.52,-0.64,
,125.62,-0.12,125.98,0.68,126.34,0.02,126.70,-0.51,
,127.80,-0.20,128.16,0.73,128.52,-0.16,128.89,-0.37,
,129.99,-0.30,130.35,0.94,130.71,-0.32,131.07,-0.28,
,132.17,-0.48,132.53,1.19,132.89,-0.39,133.25,-0.43,
,134.35,-0.16,134.71,0.86,135.07,-0.03,135.43,-0.67,
,136.54,-0.17,136.90,0.82,137.26,0.32,137.62,-0.98,
,138.72,-0.20,139.08,0.51,139.44,0.70,139.80,-0.98,
,140.91,-0.18,141.28,0.07,141.63,1.55,142.00,-1.28,
,143.11,-0.30,143.47,0.07,143.83,1.55,144.20,-1.28,
,145.31,-0.29,145.67,-0.24,146.02,2.70,146.39,-1.50,
,147.51,-0.42,147.88,-0.75,148.24,2.70,148.61,-1.50,
,149.72,-0.55,150.07,-1.15,150.44,3.00,150.80,-1.43,
,151.91,0.25,152.27,-2.27,152.63,3.00,153.00,-1.35,
,154.11,1.05,154.47,-3.00,154.83,3.00,155.19,-1.30,
,156.28,1.11,156.64,-2.94,157.00,3.06,157.36,-1.24,
,158.46,0.68,158.82,-0.80,159.18,0.51,159.54,-1.01,
,160.65,0.68,161.01,-0.80,161.37,0.51,161.73,-1.01,
,162.83,0.78,163.19,-0.67,163.55,1.02,163.91,-0.50,
,165.02,0.45,165.38,-0.70,165.74,1.18,166.10,-0.79,
,167.20,0.13,167.57,-1.44,167.93,2.22,168.29,-0.91,
das sind die Werte bei der Fahrt.
noppler
