i am about to order my wheels but i have a question before ordering, concerning the ET.
The wheels can be delivered in different ET’s and i was wondering if i order a wheel with ET 30 will it then look different from the same wheel but with etc. ET 72 ?
What i think of is if the whole midle part is changed or is it only the mounting block which is thicker on the wheels with ET 30 ?
It is a bit difficult to describe what i mean soo i have tried drawing what i mean on a picture.
The picture is here http://www.expostyling.dk/martin/rh.jpg
Changes the size of the mounting „block“ which then changes the ET but not the actually apperance of the wheel (no matter which ET, the wheels look the same).
Changes the whole middle part, this will of course change the apperance of the wheels depending on which ET they are made with.
The reason why i want to know this is of course that if it is like on nr 2 then wheels with a low ET will look to be deeper.
But the reason why i think it is nr 1 is because it is easier to make and have different sizes only by changing the middle part (the wheels are 3 parts). Also when constructing wheels the center probably have to be some certain place to give the best stability soo it cant just be change (as it would on nr 2).
But i hope some of you might know a little about this ?
Martin…
- Dieser Beitrag wurde von MartinF am 25.06.2004 bearbeitet
