Ich habe mal einen Scan gemacht, vielleicht hilft der:
Friday,07,March,2014,16:53:38:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76 77
VIN: WAUZZZ8P04A159360 Mileage: 181420km/112729miles
00-Steering Angle Sensor – Status: OK 0000
01-Engine – Status: OK 0000
02-Auto Trans – Status: OK 0000
03-ABS Brakes – Status: OK 0000
08-Auto HVAC – Status: Malfunction 0010
09-Cent. Elect. – Status: OK 0000
15-Airbags – Status: OK 0000
16-Steering wheel – Status: OK 0000
17-Instruments – Status: OK 0000
19-CAN Gateway – Status: Malfunction 0010
22-AWD – Status: OK 0000
25-Immobilizer – Status: OK 0000
37-Navigation – Status: OK 0000
42-Door Elect, Driver – Status: OK 0000
44-Steering Assist – Status: OK 0000
46-Central Conv. – Status: OK 0000
52-Door Elect, Pass. – Status: OK 0000
55-Xenon Range – Status: OK 0000
56-Radio – Status: OK 0000
76-Park Assist – Status: OK 0000
77-Telephone – Status: OK 0000
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CB HW: Bas isX 3
Component: MOTRONIC ME7.1.1G 5604
Revision: 00000000 Serial number: AUX7Z0D2FNT09Q
Coding: 0000178
Shop #: WSC 06435 000 00000
VCID: 4D9B77EDD4CA3F1
No fault code found.
Readiness: 0010 1001
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 046 D HW: 02E 927 770 L
Component: GSG DSG 0606
Revision: 03149888 Serial number: 00000403130012
Coding: 0000020
VCID: 1835D6B92B888A9
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No: 1K0 907 379 E
Component: ESP ALLRAD MK60 0103
Coding: 0021128
VCID: 346D020957204E9
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 G HW: 8P0 820 043 G
Component: KlimavollautomatH12 0150
Revision: 001937 Serial number: 8P0820043G
Shop #: WSC 00000 000 00000
VCID: 30650E19A338729
1 Fault Found:
01853 - Heated Seat; Left Front (Z45)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 65
Mileage: 180988 km
Time Indication: 0
Date: 2014.02.24
Time: 17:40:51
Freeze Frame:
Temperature: 20.5°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
Component: Bordnetz-SG 1.0 H30 0701
Revision: 00030000 Serial number: 00000000661406
Coding: A78EDF0180141000000000000000000000
Shop #: WSC 12345 123 12345
VCID: 3E792021696C949
Subsystem 1 - Part No: 8P1 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 12345
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0410602
VCID: 438F51D5028EF91
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenksäulenmodul H11 0020
Coding: 0014142
VCID: FBFF6935BAFEC11
Part No: XXXXXXXXXXX
Component: Lenkradmodul H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 G HW: 8P0 920 930 G
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2242DD09027219
Coding: 0001003
Shop #: WSC 62863 142 96259
VCID: 36693801415C5C9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 250010431002C9
Coding: FF0F07C8070100
VCID: 2855E6799BE83A9
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 53
Reset counter: 36
Mileage: 181374 km
Time Indication: 0
Date: 2014.03.07
Time: 12:04:44
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
VCID: EAD15C71C564489
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D09 Serial number: AUX7Z0D2FNT09Q
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0220
Revision: 0000012S Serial number: AUZBZ7MD200256
Coding: 0209217
Shop #: WSC 00079 211 10631
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8P0 959 801
Component: Tuersteuerger. H10 0010
Coding: 0000120
VCID: F8F576398BC8EA9
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.10 1301
VCID: 2E591061B90C649
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 188800186D288505484AC67000
VCID: F9F3733DB0C2F31
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8P0 959 802
Coding: 0000120
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000002
VCID: 387536394B48AA9
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209217
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0001003
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 A HW: 8P0 862 335 A
Component: FSE_255x BT H17 0030
Revision: 00000001 Serial number: 00000000061239
Coding: 0000411
End ---------------------------------------------------------------------
