VCDS-Lite Version: Release 1.0
Saturday, 13 February 2016, 14:06:32:0
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine Labels: 06A-906-019-AEH.LBL
Controller: 06A 906 019 E
Component: 1.6l R4/2V SIMOS 22256
Coding: 0004000
Shop #: WSC 06313
Note: Can't Synch Baud Rate
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Controller: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Controller: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03140
Shop #: WSC 06313
Address 15: Airbags Labels: Redir Fail!
Controller: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
1 Fault Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
36-10 - Open Circuit - Intermittent
Address 17: Instruments Labels: 8L0-919-xxx-17.LBL
Controller: 8L0 919 860 E
Component: AB-KOMBIINSTR. VDO D02
Coding: 08042
Shop #: WSC 42692
IMMO-IDENTNR: AUZ7Z0W0398101
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8L0 862 257 L
Component: ZV-Pumpe D05
Coding: 00000
Shop #: WSC 06313
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01360 - Switch for Anti-Theft Alarm; Open
29-00 - Short to Ground
01389 - Tailgate Open Switch (F124)
00991 - Interior Lights
28-00 - Short to Plus
End --------------------------------------------------------------------------------------------------
Das ist der Fehlerspeicher jedoch blick ich da nicht durch.
