Hi, im Andrea (Italian), i have recently buyed an old 1.8T with 240K km, but it look good…
The car run almost good, a few dead spot in acceleration and in costant speed, before do anything the vag com say theese errors:
Thursday, 13 June 2013, 19:04:50
VAG-COM Version: Release 409.1-S
Control Module Part Number: 06A 906 018 D
Component and/or Version: 1.8L R4/5VT MOTR HS D02
Software Coding: 04000
Work Shop Code: WSC 00000
6 Faults Found:
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
29-00 – Short to Ground
00529 - Engine Speed Signal Missing
06-00 – Signal too High
16499 - Engine Coolant Temp Sensor (G62): Supply Voltage
P0115 – 35-00 - -
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 – 35-00 - -
16511 - SAE: Intake Air Temperature Too High
P0127 – 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 – 35-00 - -
After, i serach in the engine for some failure, and i've found the IAT and barometric sensor unplugged, i have connect them and i've cleaned the throttle body (also the throttle position sensor).
Now the car run pretty good, the dead spot are almost disappeared (some random between 1500/2000 g/min), maybe not enough power in WOT in high revs… and the vag say this first:
Wednesday, 19 June 2013, 16:52:00
5 Faults Found:
P0115 – 35-00 - -
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 – 35-00 - -
16532 - SAE: Fuel Delivery Error
P0148 – 35-00 - -
I crear that and now vag say this:
Wednesday, 19 June 2013, 18:54:01
5 Faults Found:
P0115 – 35-00 - -
P0138 – 35-00 - -
16533 - Fuel Trim System (B1): Discrepancy in Injection Times
P0149 – 35-00 - -
I know, my english its terrible, im very noob with theese engine, and im new in this amazing community, but i really appreciate if you can help me in this adventure…
Regards
