hello
I like very much these alloys:
but as you can see in the rear wheel, there is too much gap and you can clearly see the road behind the alloy
is there any solution for this? I mean the whole alloy should be filled with black background
thanks
lonnie
2. Juli 2010 um 15:26
kind of solution would be mounting of a bigger brake disc
oh, the weight of the wheels is already heavy (18" for 1.6 101PS), adding bigger brake discs will be very negative
i think there'll be no differenz…
isn't there any other solution from Foliatec or something
if I go for bigger brake discs, I will only need brake discs or other parts as well? how much that would cost?
thanks
yes you need also some other parts.
i would try to find some parts on ebay, if i were you…
thanks for your reply
any more photos of Dotz Predator in Audi A3 8L ?
