Hallo an alle,
sind Experten hier?
fahre einen audi a3 1.8t bj 1999.
Das Auto ist auf 195ps gechippt.
Habe das gefühl das er nicht die Leistung hat welche angegeben ist.
Habe bereits das SUV getauscht (war defekt), hab den von rs6 eingebaut.
Fehler ausgelesen, alle schläuche gecheckt, konnte nichts finden.
Anbei das Log File von der letzten fahrt, 3-gang vollgas bis 6240 umdr.
,Group A:,'002,Group B:,'007,Group C:,'011
,UPM ,Zeit,Zeit,anges. Luftmasse,Lambda,Spannung ,Tastverhältnis,(keine Einheit),UPM ,Zeit,Drehzahl,Kraftstoffverbr.
,TIME,TIME,TIME,
MARKER,STAMP, /min, ms, ms, g/s,STAMP,%, V, %,STAMP, /min, ms, km/h, l/h
,1.11,1760,2.35,5.19,13.40,0.36,0.0,0.125,1.6,1.00,0.74,1720,1.90,34.6,3.8
,2.24,1840,2.10,4.42,12.64,1.49,4.7,0.730,0.0,1.00,1.88,1800,2.45,37.1,5.7
,3.38,1960,3.75,7.91,23.54,2.63,5.5,0.725,0.0,1.00,3.00,1920,3.45,38.4,8.0
,4.52,2040,2.70,5.78,17.71,3.75,-2.3,0.795,0.0,1.00,4.13,2000,1.95,39.7,4.5
,5.65,2200,4.15,8.33,29.31,4.88,3.9,0.100,0.0,1.00,5.28,2160,4.05,43.5,10.5
,6.77,2480,6.05,13.18,47.71,6.04,2.3,0.710,0.0,1.00,6.40,2360,5.05,47.4,13.2
,7.91,2840,8.40,17.93,75.97,7.14,0.0,0.780,99.6,1.00,7.52,2680,7.60,53.8,22.7
,9.03,3240,9.00,18.36,93.40,8.28,0.0,0.795,99.6,1.00,8.66,3120,8.80,62.7,28.7
,10.16,3720,8.75,18.19,103.47,9.41,0.0,0.765,99.6,1.00,9.78,3560,8.90,70.4,35.1
,11.31,4120,8.25,17.93,108.33,10.53,0.0,0.810,99.6,1.00,10.93,4000,8.40,80.6,35.7
,12.45,4520,7.95,18.45,114.09,11.70,0.0,0.835,99.6,1.00,12.08,4400,8.00,88.3,35.7
,13.59,4840,7.75,17.85,119.23,12.83,0.0,0.845,99.6,1.00,13.20,4760,7.80,96.0,35.7
,14.72,5200,7.40,17.00,122.71,13.97,0.0,0.845,99.6,1.00,14.34,5080,7.50,102.4,35.7
,15.84,5480,7.25,16.66,126.94,15.09,0.0,0.845,99.6,1.00,15.47,5400,7.35,110.1,35.7
,17.01,5760,7.00,16.07,129.03,16.23,0.0,0.840,99.6,1.00,16.61,5680,7.15,115.2,35.7
,18.16,6000,6.80,16.57,130.34,17.39,0.0,0.850,99.6,1.00,17.78,5920,6.85,119.0,35.7
,19.33,6240,6.65,16.49,132.57,18.55,0.0,0.860,99.6,1.00,18.95,6160,6.70,124.2,35.7
,20.48,4800,0.65,1.36,10.56,19.73,0.0,0.870,99.6,1.00,20.11,5480,0.55,124.2,0.0
,21.62,4560,0.50,0.94,7.22,20.88,0.0,0.030,0.0,1.00,21.25,4640,0.55,120.3,0.0
,22.77,4400,0.45,0.85,6.32,22.00,0.0,0.025,0.0,1.00,22.37,4440,0.45,115.2,0.0
,23.89,4280,0.40,0.85,5.83,23.14,0.0,0.025,0.0,1.00,23.52,4320,0.40,111.4,0.0
,25.02,4200,0.40,0.85,5.69,24.27,0.0,0.025,0.0,1.00,24.64,4240,0.40,108.8,0.0
,26.16,4080,0.40,0.85,5.34,25.41,0.0,0.025,0.0,1.00,25.78,4120,0.40,107.5,0.0
,27.31,4000,0.40,0.85,5.07,26.53,0.0,0.025,0.0,1.00,26.93,4040,0.40,103.7,0.0
,28.45,3920,0.35,0.85,4.93,27.70,0.0,0.025,0.0,1.00,28.08,3960,0.35,102.4,0.0
,29.58,3840,0.35,0.85,4.65,28.83,0.0,0.025,0.0,1.00,29.20,3840,0.35,99.8,0.0
,30.72,3760,0.35,0.85,4.44,29.95,0.0,0.025,0.0,1.00,30.34,3760,0.35,97.3,0.0
,31.86,3640,0.35,0.85,4.23,31.09,0.0,0.025,0.0,1.00,31.49,3680,0.35,94.7,0.0
,32.99,3600,0.55,1.19,6.73,32.24,0.0,0.025,0.0,1.00,32.61,3600,0.40,90.9,0.0
,34.13,3520,0.70,1.45,8.26,33.36,0.0,0.090,0.0,1.00,33.74,3520,0.70,90.9,2.7
,35.26,3440,1.25,2.55,14.17,34.51,-0.8,0.770,0.0,1.00,34.89,3480,1.60,89.6,6.2
,36.40,3440,1.35,2.81,15.00,35.65,2.3,0.110,0.0,1.00,36.01,3440,1.30,88.3,5.2
